CyberPanel Websites & OpenLiteSpeed Guides
Guide CyberPanel Rewrite Rules: Force HTTPS (301, Not 302) and Add an HSTS Header
Started by JAY 0 replies 97 views
OpenLiteSpeed reads rewrite rules from
.htaccess
like Apache, and CyberPanel has an editor with ready-made templates. We used it on our test site cyber.adminslab.com (WordPress with LiteSpeed Cache) and found two things you should know: the built-in HTTPS template uses a temporary redirect, and Apache-style
Header
lines in .htaccess do nothing.
Where to edit rewrite rules
In Websites, open your site and click Full Settings. On the Config tab, open Rewrite Rules and pick a template. Force HTTP -> HTTPS adds these lines on top of your existing rules:
RewriteEngine On RewriteCond %{HTTPS} !=on RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
The other templates: Force WWW -> NON-WWW, Force NON-WWW -> WWW and Disable Wordpress XMLRPC & Trackback. The editor shows the whole
.htaccess
of the site (ours already had the LiteSpeed Cache block), so you can also type your own rules there. Click Save Rewrite Rules; the change worked immediately on our server.
The 302 problem
Before saving, plain http gave
200 OK
(the site was reachable on both http and https). After saving the template:
curl -sI http://cyber.adminslab.com/test?x=1 | head -1 HTTP/1.1 302 Found
[R,L]
without a code means 302 Found, a temporary redirect. Search engines keep the http address indexed with a 302. For a permanent move you want 301. Change the flag to
[R=301,L]
in the editor (or with SSH) and save:
sed -i 's/\[R,L\]/[R=301,L]/' /home/yourdomain.com/public_html/.htaccess systemctl restart lsws
After changing the flag to 301, http requests are redirected permanently, keeping the path and query string:
HTTP/1.1 301 Moved Permanently location: https://cyber.adminslab.com/test?x=1
Force non-www (or www) with a 301
Use one canonical address. To send www to non-www permanently:
RewriteEngine On RewriteCond %{HTTP_HOST} ^www\.(.+)$ [NC] RewriteRule ^/?(.*) https://%1/$1 [R=301,L]
Make sure the www name has DNS and is covered by the SSL certificate, or the redirect fails with a certificate error first. See the SSL guide.
HSTS: why .htaccess doesn't work
On Apache you'd add
Header always set Strict-Transport-Security "max-age=..."
to .htaccess. We tried exactly that, restarted OpenLiteSpeed, and checked both a cached page and
wp-login.php
: no HSTS header. OpenLiteSpeed uses .htaccess for rewrite rules, not for headers.
The working way is the virtual host config.
On the same Config tab, open vHost Conf and add a context with the header at the end:
[Image: attachment.php?aid=486]
context / { location $DOC_ROOT/ allowBrowse 1 extraHeaders <<<END_extraHeaders Strict-Transport-Security: max-age=300 END_extraHeaders }
Save, and every page now sends the header:
curl -sI https://cyber.adminslab.com/ | grep -i strict-transport strict-transport-security: max-age=300
We checked afterwards that the http-to-https 301 and LiteSpeed Cache (
x-litespeed-cache: hit
) still worked with the new context.
Start small. We used
max-age=300
(5 minutes) to test. Browsers remember HSTS for the whole max-age, so if HTTPS ever breaks, visitors can't bypass it. When everything has worked for a while, raise it to a year:
max-age=31536000
. Only add
includeSubDomains
when every subdomain has a valid certificate.
  • Too many redirects: Cloudflare in "Flexible" SSL mode sends http to your server, which redirects to https forever. Use Full (strict).
  • Rule seems ignored: restart OpenLiteSpeed after editing .htaccess over SSH:
  • Site broken after saving the vHost Conf: a typo in the config. Restore your copy (
    cp /root/vhost.bak /usr/local/lsws/conf/vhosts/yourdomain.com/vhost.conf
    ) and restart lsws. Always back up the file first.
  • WordPress rules: keep your own rules above the
    # BEGIN LSCACHE
    # BEGIN WordPress
    blocks and don't edit inside them; plugins rewrite those blocks.
More CyberPanel guides
Tested on CyberPanel 3.0 (build 8, OpenLiteSpeed edition) on Ubuntu 24.04, October 2026. Menu names can change slightly between versions.
Replies:0Views:1
Replies:0Views:3
Replies:0Views:4
Replies:0Views:3
Replies:0Views:97
Users browsing this thread: 3 Guest(s)
