CyberPanel Databases & phpMyAdmin Guides
Guide CyberPanel Remote MySQL Access: Why the Panel Setting Alone Doesn't Work (Tested)
Started by JAY 0 replies 85 views
You want to connect to a CyberPanel database from somewhere else: your PC with HeidiSQL or DBeaver, a reporting tool, an app on a second server. CyberPanel has a Remote Access button for every database, so it looks like a one-click job. On our lab server (CyberPanel 3.0, MariaDB 10.11, Ubuntu 24.04) that button changed exactly one thing, and the connection still failed. You need three things, and we tested each one from a second server.
Short version:
  1. A database user that's allowed from your IP (this is what the panel button does).
  2. MariaDB listening on the public network, not only on 127.0.0.1.
  3. Port 3306 open in the firewall, for your IP only.
Before you start: do you really need it?
An open database port gets scanned and brute-forced like SSH. If you only need it now and then from your own PC, an SSH tunnel needs none of the steps below: in HeidiSQL or DBeaver choose "MySQL over SSH tunnel", or run
ssh -L 3306:127.0.0.1:3306 root@YOUR-SERVER-IP
and connect your tool to
. Use the steps below when another server or app needs a permanent connection.
Step 1: Allow the user from your IP (the panel part)
Databases > List Databases, choose the website, and click Manage under Remote Access next to the database. Enter the IP address the connection will come from.
works as a wildcard (
192.168.1.%
for a subnet), but avoid a plain
(any IP).
The Remote Access window, before saving:
[Image: attachment.php?aid=616]
We used
here as an example. After Save Changes the window only showed the new host, which looks as if
localhost
was replaced. If it were, your website (which connects from localhost) would stop working:
After saving, it lists only the new host:
[Image: attachment.php?aid=617]
It wasn't. The panel added a second user with the same name and password for that IP, and gave it all rights on this one database.
localhost
were still there and the site kept working:
What the panel really changed:
[Image: attachment.php?aid=618]
And that's all the button did. MariaDB still listened on
only and the firewall had no rule for 3306. From our second server the port was simply closed:
ERROR 2003 (HY000): Can't connect to MySQL server on 'YOUR-SERVER-IP:3306' (113)
Step 2: Let MariaDB listen on the network
On CyberPanel the setting is in
/etc/mysql/mariadb.conf.d/50-server.cnf
grep -n '^bind-address' /etc/mysql/mariadb.conf.d/50-server.cnf sed -i 's/^bind-address.*/bind-address = 0.0.0.0/' /etc/mysql/mariadb.conf.d/50-server.cnf systemctl restart mariadb ss -ltn | grep 3306
The last line must show
instead of
. The restart takes a few seconds; websites lose their database connection for that moment.
Now MariaDB accepts connections from everywhere, but the firewall still blocks them. In our test the second server still got error 2003 at this point. That's what you want: next, open it for your IP only.
Step 3: Open 3306 for one IP in the firewall
Don't add 3306 in CyberPanel's Security > Firewall page: that opens it to the whole internet. Use a rule that only matches your address (CyberPanel uses firewalld):
CLIENT=203.0.113.10 # the IP that will connect firewall-cmd --permanent --add-rich-rule="rule family=ipv4 source address=$CLIENT port port=3306 protocol=tcp accept" firewall-cmd --reload firewall-cmd --list-rich-rules | grep 3306
Our server after steps 2 and 3 ($CLIENT is the client's IP, hidden here):
[Image: attachment.php?aid=619]
From the second server, the port was now open. The error changed, and that's the useful part, because each error tells you which step is still missing:
  • ERROR 2003 ... (113) or a timeout: blocked by the firewall (Step 3) or MariaDB not listening on the network (Step 2).
  • ERROR 1130: Host '203.0.113.10' is not allowed to connect to this MariaDB server: the network part works, but there is no database user for this IP. We got this because our panel entry was for a different IP than the one we connected from. Fix the IP in Step 1. If the client is behind NAT, use the IP the server sees: it's the one in this error message.
  • ERROR 1045: Access denied for user ...: the host is allowed, but the user name or password is wrong.
After we added the correct IP in Step 1, the server accepted the connection and asked for authentication.
A client-side trap: MySQL 9 can't log in to MariaDB
Our second server had the MySQL 9.0 command line client. It got past the network and host checks and then stopped with:
ERROR 2059 (HY000): Authentication plugin 'mysql_native_password' cannot be loaded
MySQL 9 dropped that login method, and it's exactly the method MariaDB uses for normal users. Nothing is wrong on the server. Use a MariaDB client (
apt install mariadb-client
), a MySQL 8.x client, or GUI tools with their MariaDB driver.
Turn it off again
When you don't need remote access any more, undo all three steps, in reverse:
firewall-cmd --permanent --remove-rich-rule="rule family=ipv4 source address=$CLIENT port port=3306 protocol=tcp accept" firewall-cmd --reload sed -i 's/^bind-address.*/bind-address = 127.0.0.1/' /etc/mysql/mariadb.conf.d/50-server.cnf systemctl restart mariadb mysql -e "DROP USER 'dbuser'@'203.0.113.10'"
Use your own database user and IP in the last line. Check with
SELECT User, Host FROM mysql.user
that only
localhost
remain for your site's user. That's how we left our test server.
Checklist
  • Remote Access entry with the exact client IP (the one shown in error 1130).
  • Code:
    and MariaDB restarted.
  • Firewall rule for that IP only, never port 3306 for everyone.
  • Client that can log in to MariaDB (not MySQL 9).
  • Or skip all of it and use an SSH tunnel.
More CyberPanel guides Tested on CyberPanel 3.0 with MariaDB 10.11.19 on Ubuntu 24.04, connecting from a second server with the MySQL 9.0.1 client, October 2026. IP addresses in this guide are examples.
Replies:0Views:80
Replies:0Views:97
