CyberPanel Domains, DNS & SSL Guides
Guide Wildcard SSL on CyberPanel with acme.sh and a Manual DNS Record
Started by JAY 0 replies 127 views
Wildcard SSL on CyberPanel with acme.sh and a Manual DNS Record (Tested)
A wildcard certificate covers every subdomain at once:
*.yourdomain.com
is valid for shop.yourdomain.com, app.yourdomain.com and anything else you make up later. CyberPanel's normal SSL button can't issue one, because Let's Encrypt only gives wildcards after you prove you control the domain's DNS. You can still get one for free with
acme.sh
, which CyberPanel already installs. We did it on a CyberPanel 3.0.8 server without any DNS API key: we added two TXT records by hand (our DNS is at Cloudflare, but any DNS host works).
Know the trade-off first: done by hand, the certificate does not renew by itself. It's valid for 90 days, and you repeat steps 2 to 4 before it runs out. More on that at the end.
Below,
yourdomain.com
is the website in CyberPanel that should answer for all subdomains. Ours was itself a subdomain, which works the same way.
Step 1: Point all subdomains at the server
In your DNS, add one A record with the name
(a star) pointing to your server IP. At Cloudflare, set it to DNS only (grey cloud). Subdomains that have their own record keep it. The star only catches the rest.
Step 2: Ask for the certificate
Over SSH as root:
/root/.acme.sh/acme.sh --issue -d yourdomain.com -d "*.yourdomain.com" --dns --yes-I-know-dns-manual-mode-enough-go-ahead-please --server letsencrypt
The long option is real. It's acme.sh's way of making sure you know that manual mode can't renew by itself. The command stops and prints two blocks like this:
Add the following TXT record: Domain: '_acme-challenge.yourdomain.com' TXT value: 'CyX27L-gRHvJdxQgSDlVtdh0hrKv--6qIBRLKTmPYiY'
You get two different values for the same name: one for the domain itself and one for the wildcard. You need both.
Step 3: Add the two TXT records
In your DNS, add a TXT record named
_acme-challenge
with the first value. (For a subdomain like ours, the name is
_acme-challenge.sub
.) At Cloudflare: DNS → Records → Add record, Type TXT.
cloudflare acme challenge txt record wildcard ssl
Then add a second TXT record with the same name and the second value. Don't edit the first one. Both have to exist together:
cloudflare two acme challenge txt records
Check that the world can see them before you go on:
dig +short TXT _acme-challenge.yourdomain.com @1.1.1.1
It should print both values. With Cloudflare ours showed up within a minute. Other DNS hosts can take longer.
Step 4: Finish the certificate
Run the same command again, with
--renew
instead of
--issue
(and
--ecc
, because acme.sh made an ECC key):
/root/.acme.sh/acme.sh --renew -d yourdomain.com -d "*.yourdomain.com" --ecc --dns --yes-I-know-dns-manual-mode-enough-go-ahead-please --server letsencrypt
Ours took about ten seconds:
Verifying: yourdomain.com Success Verifying: *.yourdomain.com Success Cert success.
You can delete the two TXT records now. They were only needed for this check.
Step 5: Put the certificate on the website
CyberPanel keeps each site's certificate in
/etc/letsencrypt/live/yourdomain.com/
. Back up what's there, then let acme.sh copy the new files in and restart the web server:
mkdir -p /root/ssl-backup cp -a /etc/letsencrypt/live/yourdomain.com/*.pem /root/ssl-backup/ /root/.acme.sh/acme.sh --install-cert -d yourdomain.com --ecc \   --fullchain-file /etc/letsencrypt/live/yourdomain.com/fullchain.pem \   --key-file /etc/letsencrypt/live/yourdomain.com/privkey.pem \   --reloadcmd "/usr/local/lsws/bin/lswsctrl restart"
Check what the site now uses:
openssl x509 -in /etc/letsencrypt/live/yourdomain.com/fullchain.pem -noout -enddate -ext subjectAltName
Ours printed
DNS:*.yourdomain.com, DNS:yourdomain.com
and an end date 90 days away.
Step 6: Make the website answer for every subdomain
The certificate is ready, but the website also has to accept the extra names. Our server runs LiteSpeed Enterprise, where the site config is Apache-style. Open Websites → your site → Config → vHost Conf and add the wildcard to both
ServerAlias
lines (one for http, one for https):
ServerAlias www.yourdomain.com *.yourdomain.com
Save, then restart:
On OpenLiteSpeed (the free default) the vHost Conf looks different and has no ServerAlias line. We tested this step on LiteSpeed Enterprise only.
Our test results
We opened subdomains that we had never created anywhere:
yourdomain.com            200, certificate valid anything.yourdomain.com  200, certificate valid (wildcard) shop.yourdomain.com      200, certificate valid (wildcard)
Both invented names showed the main site with a valid padlock. Two subdomains that already existed as their own websites in CyberPanel kept working as before, each with its own certificate. A separate website always wins over the wildcard.
Renewal: the part you must not forget
  • Set a reminder for about 60 days from now. Then run step 2 again with
    --renew --force
    added. acme.sh prints two new TXT values. Add them, run step 4, and the certificate is copied to the site automatically (acme.sh remembers step 5). We haven't done a second round yet, since ours is new.
  • Don't click Issue SSL for this site in CyberPanel. That would get a normal certificate for the one domain and put it in the same folder. (We didn't test what happens. It's the obvious risk.) Whether CyberPanel's own renewal job touches the files later is something we can't confirm yet either, so check the certificate now and then with the
    openssl
    line from step 5.
  • Want it automatic? acme.sh can add and remove the TXT records itself if you give it an API token from your DNS host (for Cloudflare, the
    dns_cf
    method). Then renewal needs no hands. We didn't test that here.
  • Going back: copy the files from
    /root/ssl-backup/
    back, remove
    *.yourdomain.com
    from the ServerAlias lines and restart.
Questions, or a step that fails? Reply below with the acme.sh output (hide your server IP first).
Replies:0Views:165
Replies:0Views:212
Replies:0Views:268
