Guide BillionMail SSL Certificate Won't Apply: Fix Let's Encrypt Errors
Started by JAY 0 replies 27 views
BillionMail SSL certificate won't apply: fix Let's Encrypt errors
You click Apply Certificate under Settings > Common Settings and get a red box full of error text instead of a green "Certificate Valid". This guide explains the common Let's Encrypt errors in plain language and how to fix each one. For the basic setup, see BillionMail SSL and hostname fix first.
How Let's Encrypt checks your server
Before it issues a free certificate, Let's Encrypt visits your mail host name (for example
bm.example.com
) on plain HTTP, port 80, and looks for a temporary file BillionMail creates. If it can't reach that file, you get an error. So almost every SSL problem comes down to one question: does port 80 on that name reach BillionMail?
This is the real error from our test server (host and IP replaced):
Failed to apply for SSL certificate: error: one or more domains had a problem: [bm.example.com] invalid authorization: acme: error: 400 :: urn:ietf:params:acme:error:connection :: YOUR_IP: Fetching http://bm.example.com/.well-known/acme-challenge/...: Connection refused
[Image: attachment.php?aid=423]
Read it from the end:
Fetching http://bm.../.well-known/acme-challenge/...: Connection refused
. That last part tells you what went wrong.
What the error means
  • Connection refused: the server is reachable, but nothing listens on port 80. On aaPanel installs, BillionMail often runs its web interface on another port (ours was on 8080).
  • Timeout during connect: something blocks port 80: aaPanel's Security page, your provider's firewall, or a DNS record pointing to the wrong IP.
  • DNS problem: NXDOMAIN or no valid A records: the name has no A record yet, or you typed it differently.
  • Invalid response / 404 / unauthorized: another web server answered on port 80, usually aaPanel's own Nginx or Apache, or Cloudflare's proxy.
  • Too many certificates already issued: Let's Encrypt rate limits. You requested the same certificate too many times; wait (up to a week) and stop retrying.
  • CAA record prevents issuance: your domain has a CAA record that doesn't allow Let's Encrypt. Add
    0 issue "letsencrypt.org"
    or remove the CAA record.
Step 1: Check the DNS
dig +short A bm.example.com curl -4 -s https://ifconfig.me ; echo
Both must show the same IP. In Cloudflare, the record must be DNS only (grey cloud); an orange cloud sends Let's Encrypt to Cloudflare instead of your server. New records can take a few minutes to an hour to spread.
Step 2: Check who answers on port 80
On the server:
ss -tlnp | grep -E ':80 |:8080 '
  • No line with
    : nothing listens there ("connection refused").
  • Code:
    nginx
    or
    httpd
    on :80: aaPanel's web server owns port 80 ("404 / unauthorized").
  • Code:
    docker-proxy
    on :80: BillionMail has it. Good.
Then test from outside (your own computer):
curl -I http://bm.example.com/
A timeout here, while the server shows something listening, means a firewall is in the way.
Step 3: Give BillionMail port 80
In your BillionMail folder:
cd /www/dk_project/dk_app/billionmail/billionmail_XXXX # your folder grep -E '^HTTP_PORT|^HTTPS_PORT' .env cp .env .env.bak sed -i 's/^HTTP_PORT=.*/HTTP_PORT=80/' .env docker compose up -d
recreates the containers with the new port. Then open port 80 in aaPanel's Security page and click Apply Certificate again.
If aaPanel's web server already uses port 80 for your websites, BillionMail can't have it too. Your choices:
  • Best: run BillionMail on its own small VPS. Mail servers and websites are easier to keep healthy apart.
  • Run BillionMail behind aaPanel's web server as a reverse proxy. BillionMail's GitHub has a REVERSE_PROXY.md document for this. It takes more work and you must keep it in mind on every update.
  • Stopping aaPanel's web server just to apply the certificate works once, but renewal (about every 60 days) will fail the same way. Not recommended.
Step 4: After it works
You should see Certificate Valid with an expiry date about 90 days away. BillionMail renews it automatically, as long as port 80 stays reachable. Reload the dashboard; the browser warning is gone. Mail apps connecting on 993, 465 and 587 should then see a trusted certificate too.
Keep the private key private. The SSL page shows the private key in a text box. Never post it on a forum or in a screenshot.
Still failing?
Post in this section with the last line of the error, the output of
ss -tlnp | grep -E ':80 '
and whether you use Cloudflare. Hide your IP if you prefer.
Sources: Let's Encrypt: challenge types · Let's Encrypt: rate limits · Let's Encrypt: CAA
More BillionMail troubleshooting
Applies to BillionMail 4.9 installed through aaPanel or the install script, October 2026.
Replies:0Views:30
Replies:0Views:27
Replies:0Views:26
Replies:0Views:26
