FASTPANEL Getting Started Guides
Guide FASTPANEL System Requirements and Supported Operating Systems (2026)
Started by JAY 0 replies 179 views
Update, 19 November 2026: the official FASTPANEL website and its license server are currently down (the billing site no longer resolves, and fastpanel.direct shows a "We are updating our website" page that also states new ownership and an open-source license). Until that is resolved, a new install can't be activated, and details on this page may change. We'll update this post when the official site is back.
Before you install FASTPANEL, check two things: that your server's operating system is on the supported list, and that the server is clean. This page collects what the official FASTPANEL site and knowledge base state, checked on 15 November 2026. We haven't installed it for this post. Our own tested install guide, with screenshots, follows in this section.
Supported operating systems
All 64-bit only:
  • Ubuntu: 18.04, 20.04, 22.04, 24.04
  • Debian: 9, 10, 11, 12
  • AlmaLinux: 8
  • Rocky Linux: 8
  • CentOS: 7
What this means in practice:
  • For a new server, pick Ubuntu 24.04 or Debian 12. They're the newest systems on the list and get security updates the longest.
  • AlmaLinux 9, Rocky Linux 9 and Debian 13 are not on the official list. Don't assume they work.
  • CentOS 7 and Ubuntu 18.04 are still listed, but those systems no longer get regular security updates. Avoid them for a new install.
  • The feature list also says ARM64 Ready, so ARM servers are supported as well as the usual Intel and AMD ones.
Minimum hardware
The official minimum is small:
RAM:        1 GB Disk:      5 GB free CPU:        1 core, 1 GHz
That is the minimum for the panel to install and run, not a recommendation for real websites. The official pages don't give a recommended size. Remember that the same server also runs the web server, PHP, the database and (if you use it) mail. From general experience with hosting panels, 2 GB of RAM is a more comfortable start for a few WordPress sites. We'll report real memory use from our own test server in the install guide.
The server must be clean
The official wording: the panel can only be installed on a clean operating system without any preinstalled software. So:
  • Use a fresh VPS or dedicated server, or reinstall the operating system first.
  • Don't install it on a server that already has a web server, a database, or another control panel (aaPanel, CyberPanel, HestiaCP and so on). The installer is expected to fail or leave a broken mix.
  • You need root access over SSH. Shared hosting accounts can't run it.
What you need besides the server
  • An email address. On first login the panel asks for a license. You enter your email and the free license is sent to it.
  • Port 8888 reachable. The panel runs on port 8888 (
    https://YOUR-SERVER-IP:8888
    ). If your provider has a firewall in front of the server, open that port for yourself.
  • A domain pointed at the server, if you want to host a website with SSL straight away. The panel itself works on the IP address.
How installation works (short version)
From the official instructions for Debian and Ubuntu: update the system and reboot, then run the installer as root.
apt-get update && apt-get upgrade && apt-get install ca-certificates wget && reboot
After the reboot:
wget https://repo.fastpanel.direct/install_fastpanel.sh -O - | bash -
You can choose the MySQL version during installation. At the end the installer prints the panel address, the login (
fastuser
) and a generated password. Copy the password before you close the window.
We'll walk through every step, with timings and screenshots from a real Ubuntu 24.04 server, in the install guide.
Quick checklist
  • Ubuntu 24.04 or Debian 12, 64-bit, freshly installed
  • At least 1 GB RAM and 5 GB free disk (more for real sites)
  • Root SSH access
  • No other panel or web software on the server
  • An email address for the free license
  • Port 8888 open to you
Running FASTPANEL on a system that isn't on the list, or on a very small server? Tell us how it went below.
Replies:0Views:177
Replies:0Views:192
